Set timer start on dynamic panel state change?
I have a dynamic panel, the first panel has a button that on click it changes to dynamic panel state 2. On load of state 2, I am trying to have a text label start a timer that the value counts from 1-10. I can make the label and set the events so it counts from 1-10 on its own using "events" and changing the "set value" repeating 10 times.
I am having trouble figuring out how to set the load event so that on the panel state change it fires the event to force the label to start counting up. I was trying to do this on state change in the panel because I wanted to use the event timer in different pages of the app vs having to recreate it time and time again.
Hi Jack,
In this case, you can add all the counter actions next to the 'Set Active Panel' action, by clicking on the gear icon -> 'Add action' and add all the set value actions and a Pause between them. Everything should be triggered from the same event as the 'Set Active Panel' to allow the expected behaviour.
Lidia
