Dynamic internal links
How can I create dynamic internal links. I have one action that links to a login screen. After logging in the login screen should switch to the specified screen. But due to the starting action it could be different destiantions. Can I save an internal screen name in an variabel and link to that variable?
Hey.
I do not know about creating internal dynamic links.But I would like to give another suggestion.You can link one panel for each different action.When an event triggers, activate the panel corresponding to that trigger.
Hi Stefan,
You can use a 'set value' event for a variable that sets a value when only certain data is present or entered. Then, you can use an 'on page load' event to change the style or content of the screen depending on the value of the variable.
