Dependent Dynamic Panel based on Source Screen
Can I navigate to a specific panel on a destination screen based on a particular action taken on a source screen? For example...
Screen A, I add data to a form and click 'Add Entry'. On Screen B, a dynamic panel would display a table populated with 1 entry. If I go back to A and repeat my 'Add Entry' action, Screen B would now display 2 entries in the table (or another panel).
You can use the data master action events on this case.
- Create a data master with the same fields as the form
- When click on 'Add Entry', create a Data master action event of type 'Add' and add this item on the data master.
- On Screen B, drag a Data List to the screen and create an on page load event of type 'Set value' that will set the value of the Data master to this data list.
Lidia
Can i send you my model? I need to have the Data Grid on Screen B populate with Variable data from Screen A. In addition to this, I need the Data Grid on Screen B to also populate with pre-populated data (by row) and only display a row of data when a row of data has been added.
Sure, send us your prototype to us and we'll be happy to help.
