How to link each row in a Data List to different screens/panels?
I'm trying to link multiple rows in a Data List and make them show/hide different panels in a Dynamic Panel. But when I link the "Current_row_1" to something all rows inherits the link. I need to link each row to different panels or screens.
Is there any way I can target each row and set a click event on each and everyone of them? Like a row ID or something?
Regards
Sebastian
Replies (8)
You can use filtering conditions to achieve this.
For example, create a condition that filters one of the row's field, and if selected_row_ID = 1, create a link to page 1.
Lidia
Hi Lidia,
Thanks for your reply. Could you please tell me more about how a setup like that would look like? Not very experienced with the filtering condition per se.
Regards
Sebastian
Hi Sebastian,
You may find some information regarding elements in the following tutorial: http://www.justinmind.com/support/con...
Also, we can provide you an example, just drop a line to us and specify as much as you can and we will create a sample prototype for you.
Lidia
Hi Lidia
I have a same queestion. I'd like to set the text that selected from Data Master "Users-row" to a "Input Text Field"
e.g.)
Data Master : Users-row
Date Masters Fields name : Username
Selested text : 2nd row of "Username" in "Users-row"
Best regards,
Check out the attached prototype for an example.
Thank you for your support.
Your file needs to click data list. it is a nice way.
But, I'd like to select in Eventor something. I don't want to appear the list and don't select on APP.
Sincerely,
Do you have an example or screenshot of what you are looking for? I am not quite sure what you are trying to do.
Thank you for your help.
I attached document and justinmind file.
Would you check it?
Regards,
Check out the attached edited version of the prototype. I think it accomplishes what you are looking for.
I understood. I'm clear now.
I appreciate your kindness
Best regards,
I have a similar problem. I would like every cell in a data grid to show a different panel. Unfortunatley the link provided above just leads to the help center and I could not find a solution on my own.
Could you help me with this? I attached a file and an example project. Any help would be much appreciated.
Best regards
Hello, I am attaching an example.
The events are attach to [strains.name].
let me know if this is useful.
Yes, perfect, this helps a lot. Thank you!
You are welcome!
Let us know if we can help you with anything else.
