Canvas screen size and resolution
I am designing for a Nexus 5 which is 1080p and 1080x1920 display. It seems screen element are too small for this custom screen size. Should I choose a different screen size from the options?
8a1c0db3b2962f7d57ae3f132f9a799c
Hello Gabriel,
The widgets are sized in relation to the device skin intended for use, therefore they should fit. However, increasing the size of the Android device will not increase the size of the Android widget. Therefore, you will need to manually adjust if necessary. You may also use zoom when simulating if certain components need to be viewed closer.
Luisa
