Please help with ecommerce scroll funtion
Hi All,
Is there a way to create a slide function like the example here: https://www.scribd.com/books/top ?
If no, any suggestions on a work around for this?
Many thanks
Teague
Hello Teague,
This is a great example of a capability that can be completed with Justinmind's new parallax element widgets. First, you'll need to make sure the widget library is added via the widgets -> add/remove library menu item. Then, drag a pin to top parallax element and adjust it accordingly. To allow the icon and text to move right (as seen in the example), you'll need to specify an additional on scroll event that uses a move action based on a system scroll constant. Hope this has been able to help!
Luisa
