Filter Data Grid 1 based on selection from Data Grid 2
I would like to filter a data grid (contains a subset of a Data Master) on one screen by selecting a row on a data grid (containing a subset of another Data Master) on the previous screen. Each Data Master contains a common field, LoanNumber, with identical data. Can this be done?
I think so. First I'd store the selected row in a variable (this tutorial can help you with that). Then, on the other screen, create an on page load event that changes the value of the data grid (executing a set value event) and, as the new value for the data grid, build an expression like this:
filter(data grid 2, (datamaster2.LoanNumber) = (select (variable, datamaster1.LoanNumber) ) )
Hum..
That doesn't work. I've tried exactly that between 2 or 3 active panels, but data lists all records on the data set, no matter what the variable value is. This is really frustrating...
Just got it!
It's all in the expression list...
How can create this expression, can you please elaborate?
In this picture datagrid2 is datagrid, number 2 is datamaster2.loannumber and number is datamaster1.loannomber
7d445e7277b932efdea1583167fcd3ee
I hope it helps
Thanks I have managed to do it!
