Unable to link Select List to a Data Master Field as it is disabled.
Hi, I am trying to add a Select List to a data grid column and assign a data master field value to it. However when I open the Edit Values option, the Data Master Field option is disabled and I am only left with the option to link it to the entire data master. Please help.
Here's some info on Selection widgets:http://www.justinmind.com/help/index....
It says, Data Master Field: A list of category values coming from a Data Master field of type Category or Multicategory. Therefore, you have to go to your data master and change your data field type to either 'Category' or 'Multicategory'.
Thanks John.
I had same problem and after changing data field type the Data Master Field was abled. Now the problem is all data have disappeared and even *.csv file is reloaded the list is empty.
yeah all data dissapeared for me when i did this too
