How would you make a stepper using conditions?
39d974e2dbf530da716057f36abe5e5e
Hi Sam,
You should follow this steps:
1. Create an event into the minus icon --> On click - Set Value / Click into Calculated and set the following expressión : (Input text field value - 1 ) In case you want that the minimum value is 0 you will need to set a condition that the input value to be > 0.
2.Create an event into de plus icon --> On click - Set Value / Click into Calculated and set the following expression: Input text field + 1.
