How to Use Charts Widget?
Where can I find documentation on the XML structure/capabilities for the downloadable Charts widget?
Download the charts widget library from here, and then import it into Justinmind by going to Widgets -> Add/Remove libraries -> My Libraries -> Import library.
We used this flash charts http://www.fusioncharts.com/free/
Best practice: how to include charts in Prototyper http://blog.justinmind.com/how-to-inc...
Love the google charts in the HTML widget. But when I try to view the prototype in UserNote, it doesn't seem to be pulling in the google js API script reference that is in the widget's HTML.
EDIT:
Scratch that... Dumb move on my part, but worth noting in case someone else makes the same mistake. UserNote runs over https:, but the default when you create the chart HTML on the google code playground is to pull the script via http:. So if you do that, make sure you update the script reference to https://www.google.com/jsapi.
Thanks for the comment! I've updated the blog post with it.
