Upvote 6
Cannot draw a connection between components in the scenarios editor.
Not a Problem Victor Conesa 8 years ago
I'm unable to draw components between 2 components in the scenarios editor. I currently have 11 scenarios and my file is saved as a shared prototype where scenarios have to be unlocked.
It was previously working but after pulling down the latest commit, it just doesn't work anymore.
I have had this happen before and had to recreate the scenario from scratch. This feature is flakey at best.
Replies (10)
I fixed the issue by saving a copy locally. I'll later update the teamwork .vp file on JIMs shared prototype servers.
Not great but at least I can continue working. Sorry to be a pain but i'm really maximising every single feature in JIM. So I'm probably always one step away from hitting the boundaries of the app and and finding bugs.
It has done it again. I was working locally and it was fine. The moment I reshared the prototype under the "teamwork" menu item it reverted back to really glitchy behaviour.
Hi Brad,
We're sorry that you're encountering this. In order to assist you, can you describe what's happening in more detail? Do you see an error message? If possible, could you please create a video capture?
0a. Create a prototype and add a scenario based on a mixture of existing and new screens.
0b. Repeat 0a to create all scenarios
0c. Share prototype with team (via Teamwork > Share prototype)
1. Open shared prototype (Teamwork > Open shared prototype)
2. After prototype has downloaded goto scenarios tab
3. Lock scenario in the scenario panel to work on it
4. Add a 2 new screens, decisions or actions (A and screen B)
5. Try to draw a connection between them
Trying to draw a connection I get presented with the attached cursor and the line won't draw. The same icon is also presented for connecting existing screens. I can delete connections but I can't create them.
To fix the issue I have to save the file locally (File > save a copy), close justinmind and open the local copy. I can then create connections between items.
998568781b4406b1ff330c485e913b43
Hi Brad,
Unfortunately this is a bug. Our development team has already been informed. Thank you for reporting it.
Sorry for any inconvenience.
Hi Brad,
Unfortunately it is a bug. Our development team has been informed about it.
Thank you for reporting it and sorry for any inconvenience.
Regards,
I'm having the same problem.
Working on a Mac and the little arrows don't appear.
I can just drag/move the components but there is nothing to use to connect.
Hi Tiago,
Thank you for taking the time to report this. I have already informed about your issue to our development team and ask them to speed the process of solving this bug. Sorry for any inconvenience.
I need to switch to another tool again to specify scenarios - and this makes one always think about doing everything in the same place.
Has this bug for scenarios been fixed? Looking forward to trying this...
(I have the prof license subscription if that matters)
thanks in advance...
Dear Donna,
Unfortunately not. I will report again this to our development team so they can take it into account.
so this problem is not yet solved?
i am using mac and still not seeing the little two arrows when i select the screen
Dear Simony,
Unfortunately not yet. Sorry for any inconvenience.
Best
