How do i add data to a data master like sign up page so they can use it in login page?
Replies (8)
Check out this tutorial: http://www.justinmind.com/support/cre...
I dont know if you understood what i was trying to get at but I wanted it so on sign up page when they enter a new username and password it gets saved to the login database so when they login they can use the info they used to signup
In that case, create an 'On Click' action for the 'submit' button on the login page with the outcome Data Master Action -> New -> Drag the appropriate fields in the expression builder and the login will be saved into the data master.
I want a sign up page where they sign up and they can use the info they used to sign up to login
It's the same process as I described above - just start with the sign up page instead of the login page.
is it the same for phone prototyping
Yes. The process will be the same regardless of the device.
Hi Danielle I have tried dragging the fields to the correct fields and still not working...?
