Importing DataMaster CVS data
Answered Josh2876 8 years ago
Is it possible to create a Datamaster by importing a cvs sheet? I have a completely blank Datamaster (no columns) and want to import the cvs and have it create all the columns and relevant row data in the Datamaster.
Check out this tutorial: http://www.justinmind.com/support/int...
Hi Danielle. So I have to first enter all the column headers from my CVS into the Datamaster, before importing the CVS?
It would probably work best if you imported the data first and put in the column headers after.
I tried to import my cvs directly into JIM using the "Import data master from cvs" button (next to the "+" datamaster button). But i am shows the below error message. To my knowledge, non of these statements are true. Do ALL my spreadsheet cells have to have a value before importing??
57cfd1cf8377a9c3e203238d1fb2fd98
It should work - perhaps there's an issue with your data in the .csv file?
If you have purchased a license, you can send the .vp file and the .csv file over to us and we can try and import them for you and can see if there are any errors.
