RESET A VARIABLE (OR SOMETHING LIKE THIS)
Answered Filippo Andriollo 8 years ago
Hello Justinmind Community : )
I'm trying to create a numeric pad that could edit numbers into a rectangle, like a calculator, but without math operations, only to display numbers. I need to display at most four numbers together, then I need to reset the variable and make the rectangle empty again, and start editing with the numeric pad again.
I created the numbers from 0 to 9 with the "text" widget, the rectangle with the "input text field" widget, and a variable (CALC) that I modify with the event for each number:
- on tap "text1": set value (CALC.value contact to 1) to CALC
- on tap "text2": set value (CALC.value contact to 2) to CALC
- on tap "text3": set value (CALC.value contact to 3) to CALC
It works fine but not so fine as I want, because I'm not able to reset the variable (or something like this) and erase the four numbers in the rectangle. After have written four numbers, I need to erase them and write new four numbers in the rectangle.
Can anyone help me please?!?
Thank you so much in advance!
Filippo
