Bug with start date and end date into the comment search form
Known Laurent Barbareau 8 years ago
I can't filter comments by date. I guess this is a problem with the fact that your product is not compliant with local date formats...
Cf. attached picture.
As you can see, into the date fields the date format is US and into the Create column of the list, the date format is local... months and days are swapped. Then the filter doesn't work.
Thank you.
Hi Laurent,
The following tutorial should help:
https://www.justinmind.com/support/how-to-change-the-date-format-in-your-interactive-prototypes/
Also take into account that you should select the field inside the data master as a date.
The problem I have is relative to the search form of the "COMMENTS" perspective, so I can't do anything.
Moreover, I know the ugly workaround you point and I think your dev team can't get rid of the date format problem just like that...
Thanks anyway.
Hi Laurent,
We really appreaciate that you have reported this issue. We always strive to incorporate user suggestions. Our development team is aware of this issue and will take into account to fix it in future updates, but unfortunately, there is no set date yet.
