Upvote 6
An error has occurred. See the log file C:\Program Files (x86)\Justinmind\Justinmind Prototyper7.2.2
In Progress seetharam 9 years ago
I get this error while i access justinmind after updataing from 7.2.2 to 7.5, please help as its very urgent.
An error has occurred. See the log file - C:\Program Files (x86)\Justinmind\Justinmind Prototyper7.2.2\workspace\.metadat.log.
I have the same problem :(
!SESSION Wed Mar 20 11:50:58 GMT 2019 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2019-03-20 11:50:58.182
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.ExceptionInInitializerError
at java.nio.file.FileSystems.getDefault(FileSystems.java:176)
at java.io.File.toPath(File.java:2234)
at sun.security.provider.SeedGenerator$1.run(SeedGenerator.java:190)
at sun.security.provider.SeedGenerator$1.run(SeedGenerator.java:168)
at java.security.AccessController.doPrivileged(Native Method)
at sun.security.provider.SeedGenerator.getSystemEntropy(SeedGenerator.java:168)
at sun.security.provider.SecureRandom$SeederHolder.(SecureRandom.java:201)
at sun.security.provider.SecureRandom.engineNextBytes(SecureRandom.java:221)
at java.security.SecureRandom.nextBytes(SecureRandom.java:457)
at java.security.SecureRandom.next(SecureRandom.java:480)
at java.util.Random.nextLong(Random.java:424)
at java.io.File$TempDirectory.generateFile(File.java:1905)
at java.io.File.createTempFile(File.java:2010)
at org.eclipse.equinox.launcher.Main.canWrite(Main.java:1305)
at org.eclipse.equinox.launcher.Main.checkConfigurationLocation(Main.java:698)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.nio.file.InvalidPathException: Trailing char < > at index 47: C:\Users\jmoreira\Documents\MEGA\01. Go Contact \03. UX UI Go\02. Desen Dev\01. Melhorias Incrementais\01. Propostas\01. Propostas AI\19. IVR Dialer (Voice)\01. Oubound\03. Protótipo Justinmind BF\04. Protótipos alto nível
at sun.nio.fs.WindowsPathParser.normalize(WindowsPathParser.java:172)
at sun.nio.fs.WindowsPathParser.parse(WindowsPathParser.java:153)
at sun.nio.fs.WindowsPathParser.parse(WindowsPathParser.java:77)
at sun.nio.fs.WindowsFileSystem.(WindowsFileSystem.java:57)
at sun.nio.fs.WindowsFileSystemProvider.(WindowsFileSystemProvider.java:53)
at sun.nio.fs.DefaultFileSystemProvider.create(DefaultFileSystemProvider.java:36)
at java.nio.file.FileSystems$DefaultFileSystemHolder.getDefaultProvider(FileSystems.java:108)
at java.nio.file.FileSystems$DefaultFileSystemHolder.access$000(FileSystems.java:89)
at java.nio.file.FileSystems$DefaultFileSystemHolder$1.run(FileSystems.java:98)
at java.nio.file.FileSystems$DefaultFileSystemHolder$1.run(FileSystems.java:96)
at java.nio.file.FileSystems$DefaultFileSystemHolder.defaultFileSystem(FileSystems.java:96)
at java.nio.file.FileSystems$DefaultFileSystemHolder.(FileSystems.java:90)
... 17 more
It might be because this path C:\Users\jmoreira\Documents\MEGA\01. Go Contact \03. UX UI Go\02. Desen Dev\01. Melhorias Incrementais\01. Propostas\01. Propostas AI\19. IVR Dialer (Voice)\01. Oubound\03. Protótipo Justinmind BF\04. Protótipos alto nível is too long for Windows. Can you try saving the prototype in another folder just to test if that's the reason?
Does not work.
The first document created on the computer desktop opens.
The other copies of the "doc.vp" document made to other folders do not open.
The error notification appears: "An error has occurred. See the log file..."
I see. Would you mind sending the file that doesn't open to jim.development@justinmind.com ? We will take a look and see what could be going on
Good Morning @Victor ConesaI sent the email.
The problem is that there is a space at the end of the name of the "Go Contact" folder. Rename this folder and remove the space after "Go Contact" and it should open.
I need an help on urgent basis. When I open the justmind wirefarme it shows me error https://prnt.sc/svrob2
Is there someone who can help me out with?
So sorry about that! Can you attach the log file that the screenshot you attached references? You will have to compress it to .zip/.rar format to attach it here. Additionally, does the same problem occur when you try to open other prototype files, or is it only that file?
