Installation of Jira Plugin does not work.
Known Johanna Wolke 8 years ago
the installation of plugin "com.justinmind.plugins.jira_1.0.0.jar" is not working on iOS.
The following error message occurs:
"Failed to connect (_consoleX) outlet from (NSApplication) to (ConsoleX): missing setter or instance variable"
How can I install and use the Jira Plugin properly?
Cheers
Johanna
Hi Johanna,
Can you specify which OS are you using? The following tutorial should help to install the plugin properly.
https://www.justinmind.com/support/integration-with-atlassian-jira-importing-and-exporting-jira-issues-in-justinmind-enterprise/
