Advice on how to create specific interaction - add subrows to selected rows
Answered Luiza Oancea 8 years ago
Hey,
I have this interaction in mind for web, that I have prototyped in Powerpoint and I am wondering how I can do this (or if it's even possible) in Justinmind. Check the ppt file I attached for example.
So, in a table, I want to be able to select different product lines by changing the background of that row. And then, at the click of a button, I want to add sub-rows to the selected rows. I think I should manage making a box pop-up with drop-down.
Thank you! :)
Hi Luiza,
The following tutorial should help you to select different product lines in a data list by changing the background of the row.
https://www.justinmind.com/support/change-the-color-of-a-clicked-data-list-row-in-your-web-prototypes/
Thank you for the tutorial Sonia! What about the ability to add subrows to the selected rows? Do you have any advice there?
Luiza
Hi Luiza,
Can you attach an example of what you are trying to accomplish?
I attached a PowerPoint in the first post with the kind of interaction I want to achieve in Justinmind :)
Luiza
Hey Sonia,
Do you have a suggestion based on the interaction I want to achieve? Check the attached ppt in the first post.
Luiza
Hi Luiza,
Please find attached two examples. Hopefully they might help you to get some ideas.
