Browser widget
Known Marlon 8 years ago
I used the browser widget with a url to google maps. the map is showing and it works fine but i want to let a different layer slide over it and this doesnt work :(
The layer with the url is below the layer i want to slide over it.
Hi Marlon,
Unfortunately the url widgets are set at the front by default. You won't be able to add a layer on it.
Sorry for any inconvenience.
You can put a Browser Widget in a Dynamic Panel A, Panel 1, then put that Dynamic Panel A in another Dynamic Panel B, Panel Slide 1, And then you can have Dynamic Panel B slide a new Panel Slide 2 over Slide 1. I believe that will get what you are after.
