Showing/Hiding Group of Elements
Answered Brandon Coffey 8 years ago
I'm trying to add a show/hide toggle to group of elements when a another group of elements are clicked. I can't seem to figure out the proper events to use.
Please advise.
Thank you!
Hi Brandon,
While you can apply the result of an event to a group of elements (i.e. - Hide/Show), you can only have the start of the event (i.e. - the On Click) to one element and not a group. As a workaround, you can use a hotspot for the area where the group of elements is.
Hi Danielle,
Got it. What string of events do I need to add to the hotspot for a group to show when another group is clicked and then be hidden when the group is clicked again.
I'm ultimately trying to mimic a dropdown showing/hiding when clicked.
Thanks,
Brandon
Hi Brandon,
Actually, the event is a little more complicated than I first described, and involves using a checkbox or radio button instead. The 'on toggle' event is necessary to create the interaction.
You can check out the example of this here: https://dl.dropboxusercontent.com/u/46967405/ShowHideGroup.vp
Let me know if you have any further questions.
