HTML Widget - Get Variable Value from Input
Known Matt Low 8 years ago
I have a screen that has a Select List component (dropdown) and an HTML widget. I've created a variable in my project called 'SelectListValue'. I'm doing some things with Google charts in the HTML widget's HTML section where I'd like to get the selected value of the dropdown. Can this be done either through my SelectListValue variable or otherwise? I would think that if my screen knows about all three components: dropdown, HTML widget and variable, it should be possible. Thanks in advance.
Matt
Hi Matt,
Unfortunately you won't be able to detect values within an HTML widget - so this won't be possible to do.
