Add new data master row with an incremental id number.
I want to add an entry into a data master, and assign the column "id" by an increment of 1. For example, when a new user is created, we give him user id of last user + 1
Replies (8)
currently, the method i'm using is for datamaster "users" new[id=[data_max[users,id] + 1], ...]
Hi Kent,
Please find attached the example I've created for you. I hope it helps.
https://www.dropbox.com/s/u922pycmp0l...
Hi Sonia, thanks for the reply. I think I'm doing the same thing. Does the data save between sessions?
Hi Kent,
No, the data is not being saved between sessions.
Is it possible to save data to master permanently?
Or for example, in a mobile template, have all data displayed somewhere (preferably on the side somewhere) for debugging purposes.
Hi Kent,
Unfortunately we do not have any interface for debugging purposes. As a workaround, you can create set value events associated to any element and display it into a label.
Thank you for your suggestion.
Sonia Duran
Hi Kent,
The data of the data master are the ones that have been kept inside to it.
Sonia Duran
