Sorting data in Data List from A-Z then switch it from Z-A by clicking the same area?
Answered Kevin 8 years ago
Hi -
Is it possible to sort something ascending order then switch it to descending order by clicking the same area in a data grid? I'm trying to make it so that this occurs when I click on the Column name in a Data List.
I can make it go one or the other, but I can't figure out how to alternate. I do not have room in my table to add two buttons like the example in https://www.justinmind.com/support/prototyping-sortable-columns-for-your-data-list/.
Please help -- I really need this for my occupation.
Thank you!
Kevin
Hi Kevin,
You can create a variable that will detect if the data list has already been sorted. Then, create another event that will sort the data list from Z-A with a condition that will detect if the variable is true or not.
And this can be done with a data master?
What would be example logic of the second event? Im trying to figure that part out. My variable for the first sort is called Ascending.. data master DM1. Thanks, sorry I am new to this.
Hi Kevin,
This example should help: https://www.dropbox.com/s/4wnkxzfztxtdx0u/Sort.vp?dl=0
