How to freeze the header fields of a Data List in a Dynamic Panel scroll?
Answered Kevin 8 years ago
Hi -- How do you freeze the header fields of a Data List when scrolling with a Dynamic panel?
It allows you to "Group in a Dynamic Panel for the entire Data List but not just the entries... This makes it so that when you scroll, the Header disappears as well.
Please help. I can't figure it out.
Thanks,
Kevin
Hi Kevin,
You can create a parallax element that will pin the headers to the top of the dynamic panel. You can learn more about parallax elements here: https://www.justinmind.com/support/how-to-design-a-fixed-position-menu-in-your-wireframe/
Hi Danielle --
It is a part of a Data List pulled from a Data Master. Does that change anything? Do I need to create a Widget of the Data List Header in order to drag onto the Floating menu?
Thanks,
Kevin
Hi Kevin,
You'll need to create another version of the header and place it within the floating menu. This example should help: https://www.dropbox.com/s/3znb4un00hclzjm/FloatingMenuDataList.vp?dl=0
I had the same problem.
Here my workaround :
- Create a dynamic panel named "Dynamic_Panel_Main" (that creates a panel "Panel_1" -> rename it "Panel_Main" )
- Add a new dynamic panel in the panel "Panel_Main" (that creates a panel "Panel_1")
- Set the top value of this sub dynamic panel to 35 (the height of the header)
- Add your Data list in the Panel_1 (set the vertical overflow to scroll always)
- Select the "Header_1" in the Outline and set the Height to 1
- Add a copy of your Data List in the panel "Panel_Main" (top at 0, 1 row per page, height to 37)
That's all.
