Can't edit a new screen
Known shira nezer 7 years ago
Hey All,
I'm totally new to this so sorry if this is a noob question:
When I try to add a new screen it adds it with a red symbol (attached) and everything is greyed out and I can't edit.
Can someone please explain why it's happening?
Hi Shira,
You might be confusing the content at the Template instead of the Screen. Can you check out at the outline tab that the items you are trying to modify are there?
Hey,
Thanks for your answer,
Indeed that was the problem, the items on my main template didn't show up at the outline tab, is it supposed to be this way?
Or every item on the template is supposed to be created automatically when using a new screen?
Thanks again :)
Hi Shira,
You are right, the items on the template will be created automatically when using a new screen.
