Events Toolbar not Visible
Maybe I am missing something, but I can't seem to get my event toolbar to appear anywhere on my UI. Any help?
Hi Max,
Are you using the free version? If so, you won't have an event toolbar.
However, if you're using the Pro version, go to View -> Events and check that. If that doesn't resolve this, check to see if you have minimized the events panel at the bottom of the page.
Hi Max,
That would explain it, I am indeed on the free version. Thanks!
is it possible in Free version? because i am using free version...So
After your trial expires you will not be able to use Events.
okay....
thank you.. for your support
Hi! i am using the trial version, would i be able to see the events button?
Yes, you will be able to use Events for the duration of your trial. After your trial expires, you won't be able to use events anymore.
The same thing just happened to me. Go to View, then click 'Reset workspace' and the 'Events' panel will open if you have the subscription.
