How do you use a shape/object to change the position of an element on the client?
Answered Carlos 7 years ago
I am trying to create an interaction where the user would press a triangle up or triangle down an element on the screen would move up or down a certain amount of pixels. Is this possible?
I tried using the "Move" interaction and adjust the item using a calculated value. But I am not sure I am doing it correctly.
I have attached a screen shot of the element I would like to move a certain pixel.
I hope this makes sense.
Hi Carlos,
You will need to create a Move event / Offset and then select the desired pixels.
