How to add a text/ button over an image which is inside a cell?
Not a Problem Snehashish Panigrahi 7 years ago
I am building a responsive site. So as suggested in example I went with a table layout for the entire page. And, placing elements in cell. Facing problem, when there's an image inside cell, and I want to add text & button on it. How do I achieve that?
After placing the element on the canvas, you just need to drag the element into the table through the outline panel. You'll know it has been correctly dragged into the table when you look to the outline panel and see the image or text within the cell.
I have done in the similar way to get the image in the cell. Probably you didn't get my query. Please see the attached image. The big image is already there in the cell. And, I want to insert another TEXT element in the same cell but over the image. I am facing trouble when I try to place the TEXT on the image. It doesn't allow and the TEXT stays outside of the image.
It's required. I'm not finding any alternative to this. In Axure I am able to achieve this.
Apologies for any miscommunication. You can do this by changing the layout of the cell by selecting the cell, then looking to the properties panel and change the layout from vertical to free. See the attached screenshot.
