Is there a look alike for SQL "LIKE" query in justinmind.
Answered Krishna Lahoti 7 years ago
I have a custom select list with alphabets as values. I want to display usernames which start with "A" when "A" is selected from a custom select list
Dear Krishna,
You will be able to accomplish that by using data masters (including all the usernames) and creating a filter. At the filter, you should use the "Has" or "Regular Expression" functions.
The following tutorial should help to get some ideas: https://www.justinmind.com/support/how-to-filter-data-list-columns-in-your-web-prototypes/
thanks sonia for the help but this works fine when my username has letter "a", my requirement is i want to filter usernames which start with "a" only.
Hi Krishna,
You should add the expression attached to the event.
thanks it works fine i was trying to do this but could not get it properly.
