Color of image changes when data grid is filter using "set value"
Known Ben W. 7 years ago
I wanted to filter a list like described in this tutorial. The filtering works, but the color of the images in the cells change to default.
I stripped down the prototype to show the problem.
Dear Ben,
The prototype attached is incomplete. It just includes a set value event so I can't see the events that you have created related to the color of images. If possible, can you attach again a complete example.
Dear Sonia,
I'm not sure, what you mean. There ought to be only one set value event. After the set value-event is executed the color of the icons in the grid change. I have not put any color change event in the prototype, since I don't want the color to change. I attached a small video to show the behaviour. In the video you see the tap and the color change. But there isn't any color change event.
Is there a different behaviour on your system?
Greetz
Ben
Dear Ben,
Unfortunately it's a bug that will need to be solved by our engineers on future updates. Thank you for taking the time to report this and sorry for any inconvenience.
Best
Dear Sonia,
I thought so. :) I hope my prototype helped replicate the problem
Greetz
Hi Ben,
It will :) Thank you so much!
Best
Hi Sonia,
I stumbled again on this bug. Should that be fixed right now or is it still in your backlog?
Best
Ben
Hi Ben,
What version of Justinmind are you using?
Hi Danielle,
there was no answer in this post, that is why I asked. I'm using 8.4.3. the bug appeared again at one time. But when I tried to reproduce it, it disappeared. It did not appear again.
Best
Ben
Ok, thanks for the info. If this happens again, please let us know, and list the steps to reproduce the issue.
