Horizontal Line does not display in simulation properly
In Progress Adria Robinson 7 years ago
We noticed that horizontal lines and other elements do not align properly in Simulation. They are aligned in the actual prototype but when the prototype is simulated, the alignment is "off". See the attached images. The "inProtype.png" is a menu item in the actual prototype with a red horizontal line under it to indicate that the user is in that section of the site. The "insimiulation.png" file is how it looks when the prototype is simulated. The red line is shifting to the right for no reason. Other elements also do this but it is most noticable when you have something in context to it (like the line under text which needs to align properly).
Hi Adria,
Thanks for reporting this. If possible, can you attach the .vp file in which this occurs so we can investigate this further? You'll need to export it to a .rar format, or you can upload it to a file sharing service like Dropbox and attach the link here.
Did this ever get fixed? What is the answer? I have the same issue, where an entire line of tabs is showing up about half way down the page during simulation, rather than being at the top of the page as it is in the actual prototype.
Can you attach the .vp file here so we can check this out? You can compress it to .zip/.rar format to attach it.
I've attached the file.
Is there an update on this issue?
It's so weird. It only happens with one of the panels. We'll debug and see what is going on.
Yes exactly, so weird! When I created the set of panels, they were all duplicates of the first panel I built, so there shouldn't be any difference between them other than color changes.
We were able to isolate the issue. It's related to the rounding on the CustodyClass panel. For some reason, it shows a round of 30, even though there is no border to be rounded. During simulation, though, the panel shifts as if there is a rounded border. If you change the round of the CustodyClass panel to 0 it will work correctly.
It works now! Thank you!
Glad to hear it! We're going to fix the underlying issue soon as well.
Awesome. Is there a way to delete the link to the prototype I sent you guys? I would like that removed now that the problem is solved.
Sure - I've deleted it.
Great, thank you!
