Show SOME values of a custom select list as disabled
Answered Judit 7 years ago
I'm trying to show some of the values of the custom select list look like disabled (grey). How can I do that?
Dear Judit,
Unfortunately, there isn't an automatic way to select as disable some values of a select list. As a workaround, you can simulate that by using a panel with a layout and one label at each item. Then you should configure the desired styles.
