I would like to resize an image from the center instead of top left corner, is that possible?
Answered Judit 7 years ago
I'm implementing a zoom image functionality and I would like the image to increment according a percentage from the center instead of the top left corner.
I've tried different options:
  1. move the image after the resize but it looks weird. I can't do it the same time because then looks it doesn't know the size of the image and goes out of the panel.
  2. Use a dynamic panel with a centered layout but then I lose the drag and drop functionality
  3. Use different panels but I lose then the zoom in effect
Is there any other option to try? Thanks!
Dear Judit,
The correct option is the 1 and should work. If possible, check out if the "move" and "resize" expressions have been set correctly,
