How to use Stack Navigation ?
In Progress Mark Qian 7 years ago
I tried to use this widget and added two panels but the second panel (I drop a text into it) always shows nothing.
I used event to show/hide the panels insdie Stack Navigation, is it the correct way?
regards
mark
Replies (6)
Hi Mark,
Make sure you're dragging the text widget correctly into the dynamic panel. You can check this by looking to the outline panel, and see if the text widget is in panel 2, and isn't on top of the dynamic panel.
If you're not sure, if possible, attach a screenshot of your outline panel.
It is inside the panel2
/kfqA8YAMf+DBASAAMAAAARMLYAAEBSmAFMsgmAAQAAgAgYWwAAICkEwCSbABgAAACIgLEFAACSQgBMsgmAAQAAgAgYWwAAICkEwCSbABgAAACIgLEFAACSQgBMsgmAAQAAgAgYWwAAICkEwCSbABgAAACIgLEFAACSQgBMsgmAAQAAgAgYWwAAICkEwCSbABgAAACIgLEFAACSot4A+L+UUkoppZRSSimllFJKKaWUUkptixIAK6WUUkoppZRSSimllFJKKaXUNikBsFJKKaWUUkoppZRSSimllFJKbZP6D1jrjGWQ8oIfAAAAAElFTkSuQmCC
result
/wNGq3suolhmiwAAAABJRU5ErkJggg==
The vp file is available at
http://coolshare.com/temp/netelastic_ui_1.vp
Hi Mark,
The issue is that you need to create a 'set active panel' event instead of a show/hide event. Create an 'on click -> set active panel' event for the 'manage user' text, and have it set 'panel 2' as active.
Hope this helps.
Cool! It worked
Another question: how can I place checkbox in the first column of a table so that we can select a row in the table?
Which table should I use?
thanks
