Syncing between Sketch and JustInMind
Answered Rachel T 7 years ago
I am using the new Justinmind plug-in for Sketch. Is it possible to sync or export specific mockups/artboards from Sketch to Justinmind without having to run the export plugin across the entire file? For example: my sketch project contains about 50 screens and I have made updates to three screens. What is the best way to update the three screens in Justinmind without having to export all 50 screens from Sketch?
Hi Rachel,
You could create a new sketch file from those three screens, and then export those three screens to a .vp file. You can then import that .vp file into the larger .vp file by going to File -> Import prototype.
Hope this helps.
