How create two actions on one button and select in the data list select 3 colors differents
Answered kaitozala 7 years ago
I have two questions on justinmind. The First, it's possible to create 2 actions on a button (on click), for example when i click a boutton it's show the panel and i reclick the button it's hide the panel.
My second question is; It's possible in the data list in a the column select different color. For example when in the data list I select a category, it 's purpose different elements , i would it's possible to choice in each element to choice a different colors.
Kaito
1) Yes, using conditions. Check out this tutorial: https://www.justinmind.com/support/how-to-define-cases-in-your-prototypes/
2) This is also possible. Check out this tutorial: https://www.justinmind.com/support/change-the-color-of-a-clicked-data-list-row-in-your-web-prototypes/
Hello Danielle,
Thanks for your answer.
1) I have a problem, I need your help. When i click add conditions, i have edit the drag & drop a component, i have a error, i chose "when image = panel"
The goal is when i click the picture, it's shows the panel and when i reclick the picture, it close the panel.
a90f3a02b38f9b8c7f5c050fa68e9b51
Kaito
You need to change the condition to When... panel (is visible). Check out the linked prototype. https://www.dropbox.com/s/8hzp4nxrmnrzoxo/clickimageshowpanel.vp?dl=0
Hello Danielle,
Thanks you for your answer,
For the second it's no good sorry, I would in each category and in each coloumn (in data list) i need to put 3 colors differents (see the picture below). It's possible ?
fed281d7a061408485097fdca266ce0e
I'm not quite sure how you're formatting your data list here. If possible, could you attach the file you're working with? You can attach it in .rar format, or upload it to a file sharing service like Dropbox and link to it here.
