Image in data grid get lost
Known Jonathan Serex 7 years ago
I am facing an issue:
I have a data grid, which includes some icons. These icons are loaded in my data master with the function "file upload".
Frequently, (once or twice a month), and without clear triggering factor, these images get corrupted. (see screenshot).
I am sorry that I cannot provide more detail which would help you to reproduce this bug, but I was wondering if you may be already aware of this issue and would have some info on how to avoid/fix this problem ?
At the moment this is quite annoying because each time the problem occurs I have to re-load my data master in order to re-upload the images.
Thanks in advance for your support !
Jonathan
P.S
In case this has an impact, I use the PC version of JustinMind.
Dear Jon,
Which Justinmind version are you using? Also, can you let me know the extension of the image file (jpg, svg...) ?
Hello Sonia,
I'm using the version 8.01 of JiM.
fyi : I was also facing this issue with past version of JiM.
Thanks for your support !
Jonathan
Dear Jon,
Unfortunately we haven't been able to reproduce your issue. If possible can you send us a snippet of your prototype so we can try reproducing this.
Hi Sonia.
Thanks for your feedback.
Next time the issue happens I'll send you my prototype for your analysis
Kind regards,
