Need to perform bulk update on specific rows in a data list
Answered prototype user 7 years ago
i need to perform a bulk update from a data list based on the value of user-defined fields for each row (Ie..e, when the value for a given row is "a" then the given row should be deleted, else it should not). Please advise.
Hi Rechell,
First, look at this tutorial to learn how to perform data master delete actions: https://www.justinmind.com/support/delete-rows-from-a-data-list-in-your-web-prototypes/
Instead of having the event be an 'on click' event, have it be 'on key up' for the user defined field. Then, create a condition for this event that is When... [user defined field] = 'a' (or whatever value you'd like).
Hope this helps.
