Link Select List to Data List
I want to be able to select a value from a select list on the side of the page, which in turn populates the data list with the record i have selected from the Data Master. Is this achievable?
Hi Justin,
I've created a simple example for you. I hope it helps.
https://www.dropbox.com/s/ratkrtv59gb...
This tutorial should also help.
http://www.justinmind.com/support/add...
Hi Sonia, thanks for the tips but i should have been clearer with what i was asking. I have a data master set up with the values that i want to display. However i don't want the data list on my page to display these values by default. I want to select a single value from the select list that when chosen will make that record appear in the data list.
Hi Justin,
Data masters have been created to show the data that have been included. However you can delete the records and add the values from the data list into the empty data master. Another option is to include all the values from the data master into the data list by creating two data masters one empty and the other one with all the values included.
Please find attached this new example I've created for you. I hope it helps.
https://www.dropbox.com/s/z3poxsi4427...
