"LOCK HORIZONTAL SLIDE" DISABLES SWIPE GESTURES
Known Mateusz Główka 7 years ago
I have a problem. I have a simple iPad prototype with 3 screens which are connected with swipe-right/swipe-left gesture. Now on one screen I have a dynamic panel which is bigger than the screen since I have some blocks of text sliding in on page-load from outside of the page. To prevent the user from sliding sideways because of the bigger dynamic panel I've locked the horizontal slide in page attributes. Now the swipe gesture doesn't work. It seems to work fine on the PC simulation, but on iPad it does not.
I presume it's a fault in the Justinmind program, not fixable right now, but can you tell please tell me instead how to make something slide in from outside of the screen without having to put it actually outside? That way I would keep the animation, but I would also not have to lock the scroll...
Thanks!
Matt
Just curious why the dynamic panel is bigger than the screen. Would a dynamic panel that is not bigger than the screen with the slide-in text box(es) positioned off screen then moved into place on page load get you any closer to solving the problem?
It did! Thank you very much. I was under the impression that the dynamic panel must be at least the same size as the content. It did not resolve the error, but did help me a lot! :D
Ok, now that's done, I've locked the horizontal and vertical scrolls and the swipes stopped working. Weirdly, the swipe right/left doesn't work when the VERTICAL scroll is locked and works just fine with the horizontal lock on.
What is it you need the dynamic panel for? If it only contains the slide-in text box(es), you can simply position those off the screen and move them in on page load without the dynamic panel. Is there other scrolling that you are using the dynamic panel for?
See attached prototype and let me know if this is close to what you're looking to do. (It's not compressed. Just change the .rar extension to .vp)
