Using check lists to retrieve data from a data master
Answered prototype user 7 years ago
I am trying to write an expression that will retrieve records from a data mater based on values selected in a check list widget. For example, each checkbox in a list represent colors: red, green, and blue. If the user selects the red and blue checkboxes I want to retrieve all items that are either red or blue. I am able to get it to work if only a single checkbox is chosen, but when multiple checkboxes are selected it doesn't work at all. It seems like if red and blue are chosen it is mapping it to a string "red,blue" and will only match a data master column that also happens to have the string "red,blue". Please advise.
What expression have you created to filter the data master? Does it include filtering by the attribute color using the 'OR' comparator, or does it use '='?
