Tables not resizing properly within a dynamic panel
In Progress Sharovipteryx 7 years ago
When a table has more than 1 column and is inside a dynamic panel then when all the columns (cells) are made to expand to 100% of the width of their parent (the dynamic panel) on the event of window width of the browser changing the last column on the right doesn't resize to 100% of the width of it's parent. Instead it gets clipped off and the other columns resize to take up the missing space.
This also seems to lag the browser. It doesn't do this when it's just one table and if you minimize or maximize the browser window the table fails to resize to the proper size (the width of it's parent which in this case is the dynamic panel that the table is in).
Dear Sharovipteryx,
Sorry for our late response. Do you have an example .vp file of what you're describing so we can test it and take a look? You can attach it in a .rar format, or upload it to a file sharing service such as Dropbox, and attach the link to it here.
