Can I change the setting in Widgets, Web components, Text, Page header(H1), Body etc.?
Answered Enver Simsek 7 years ago
Is it posible to change the setting in Widgets, for Page header(H1), Body, etc. as default to the requirements i need?
E.G. the Corporate Design requirements
Hi Enver,
Sure - first drag all the elements you'd like to customize onto the canvas, and customize them how you'd like. Then, you can create your own widget library by going to Widgets -> New widget library. You'll then be able to drag the customized elements into that library and then save the library. You can then load that library whenever you would like to use the style of widgets.
