Refine Dropdown choices based on Variable (Data Master-populated dropdown)?
Answered Benja 7 years ago
Is is possible to have conditional/dependent/linked dropdown that is based on a Data Master?
I saw the tutorials and posts about creating a linked dropdown, but that just describes hard-coding the values and brute forcing the trimming by if/then/else statements.
I also saw how to trim Data Masters list/grid views dynamically based on user's selection.
However, I need to let the user select from one drop down, and then based on their selection, offer choices in the second dropdown that match on a given field in the second..
I figured out how to save the selection from dropdown #1 to a variable, but there doesn't seem to be any way to use that to filter the items sown in dropdown #2.
Hoping I'm missing something obvious?
Any ideas greatly appreciated!!
:)Ben
Example:
Data Master #1:
Condition_ID
Condition1
Condition2
Condition3
Data Master #2:
Condition_ID, Symptom_ID
Condition1, Symptom1
Condition1, Symptom2
Condition1, Symptom3
Condition2, Symptom1
Condition3, Symptom1
Condition3, Symptom2
Condition3, Symptom3
Condition3, Symptom4
  • Dropdown #1: Offers all items in Data Master #1
  • Dropdown #2: Offers nothing until something selected.
  • Users Selects "Condition3"
  • Dropdown #2: Refreshes to offer: Symptom1, Symptom2, Symptom3, Symptom4
Yes you can. The key is using categories at the properties of a DataMaster. The following example should help.
Worked like a charm; thanks again!
:)Ben
Thanks, Sonia! Will give that a shot now.
Cheers,
:)Ben
I am unable to do this in the latest version I downloaded yesterday :(
very frustrating. I just can't find my way around this
I first added 3 fields A, B, C
Then tried adding values A1, from the VIew and Edit Records Tab manually. it would only give me a blank dropdown and I wasn't able to update the values
I tried importing values for 3 fields as text first and then converting the Type to Category. but it ended up populating blank values for all rows again with blank dropdown
Would you mind attaching an example of a prototype the way you're doing it?
Doesn't work for me. The problem is that I can't use category field type in data-master, cause the values of the field must be editable in another dialog and data-master-category-type fields are not editable.
What I want to do is set and filter the content of the Category Control on the fly.
Hi, were you able to solve your issue? I have similar problem. I'm working on a search page with grid display and dropdown, date and radio button fields as search inputs. I want the dropdown and date fields value to filter distinct values from the data masters filed. I hope this is possible.
