Toggle through status list
Answered Omadi UX 7 years ago
I am designing an interface where I have a button that updates a status (Dispatched, At Scene, At Destination, Completed). Each time button is clicked the text in the button needs to update to the next status. Of course, I could do this manually with events and dynamic panels (updating and displaying a variable) but that seems like overkill.
Is there a way I can do it via a Data Master? Where each time the button is clicked it just updates the text to the next status in the list? Any help is much appreciated.
Dear Jeremy,
You should follow this steps:
1. Create a DataMaster with 2 columns.
2. The first column should include some correlative ID's (Example: 1,2,3...)
3. The second column should contain the different status (Dispatched, At Scene, At Destination, Completed...)
4. Then you will need a variable that contains the current status.
5. Add an "on click" event at the button and add +1 to the current status.
6. Finally, add a "set value" event in order to search the text of the data master using the value of the variable.
Hope this helps.
