ApiWidgetName not found for several justinmind controls
Known jolly thakkar 7 years ago
We are implementing justinmind plugin in Eclipse SDK.
We have requirement to get the control type of all dropped controls in screen.
For example, We want to get the control type of below controls.
1. Label
2. Textbox
3. Line
4. Select List/Custom Select List
5. Dynamic Panel
6. Data Grid
7. Data List
etc..
We are able to get the control type of several controls (label, textbox, button) using below code.
IPrototype prototype = API.getPrototypeLoader().loadPrototype(temp_directory+File.separator+"work");
List<ICanvas> canvas = prototype.getApiCanvases();
for(ICanvas iCanvas:canvas)
List<ICanvasComponent> lstICanvasComponent = iCanvas.getApiRoot().getApiChildren();
for (ICanvasComponent iCanvasComponent : lstICanvasComponent)
String controlType = iCanvasComponent.getApiWidgetName();
System.out.println("Control Type :" + controlType);
Output:
Control Type :Label
Control Type :Button
etc...
So, can you please suggest how to get control type of rest of justinmind controls ?
PFA for identifying the control names.
I'm not able to get the widget name of below listed controls.
1.Basic
Paragraph
Text
Button
Input Text Field
Text Table
2.Lines and Shapes
Line
Rectangle
3.Forms and Inputs
Check Box
Radio Button
Date
Select List
Custom Select List
File Upload
List Box
4.Dynamic Content
Data List
Data Grid
Dynamic Panel
Summary
can you please suggest about solution or alternate way ?
Dear Jolly,
The following method "String controlType = iCanvasComponent.getApiWidgetName();" returns the name of the element, or in case it is a "mywidget" gets the name of that "mywidget".
Also, can you specify which are the Justinmind controls you are having issues?
1.Basic
Paragraph
Text
Button
Input Text Field
Text Table
2.Lines and Shapes
Line
Rectangle
3.Forms and Inputs
Check Box
Radio Button
Date
Select List
Custom Select List
File Upload
List Box
4.Dynamic Content
Data List
Data Grid
Dynamic Panel
Summary
Dear Jolly,
Can you send me the complete project of the API? Also, can you let me know which version of the API are you using?
We are making justinmind plugin in Eclipse SDK as described earlier in this topic.
Version Information:
Eclipse SDK : screenshot "EclipseVersion" attached
JustInMind : screenshot "JIMVersion" attached
API Details:
JustInMind PlugIn project "JustInMindControlTypeDemo" attached
Prototype File "TestPrototype.vp" attached.
Dear Jolly,
We've been testing this issue and it will be solved on our next release.
Thanks for update!
At what time should i expect the next version's release?
Dear Jolly,
Unfortunately there is no set date yet. Probably in January.
