Add variables to widget library
Would be great to add the ability to add and export variables with a widget library.
Use case:
Let's say you define specific margins / paddings with variables. On the ResizeEvent you could use this variable to set the right margins/paddings. If you change the variable one time, all items will be updated. This works great.
However, adding the controls to a widget library, exporting them and re-using them in a new project would result in a loss of variables. You need to re-create them.
Hi Niels,
Thank you for your suggestion and helping to make Justinmind better. I will transfer this information to our development team so they can take into account for future updates.
