Event trigger for "dynamic panel" panel change
Known Mursel 7 years ago
Is there an event trigger when we change from panel1 to panel3? On page load does not seem to take affect for this purpose. I want to assign an input text field value to a variable and use this variable content at another panel. So in the latest panel variable value will be assigned to an uneditable input text field. So far I could not find a suitable event trigger.
regards
Mursel
I found the answer myself :) Instead of creating an event for the text input field, I created an event for the panel with "On Panel Active" event. Currently this solved my issue.
Normally I want to have this happens when there is a change on the source text input field.
thanks
