Refined searchs in datamaster
Hi i ́m working this application and i have a question, i have a datamaster with some information (social number, name, phone, mobil, addres) and i want to select only name based in social number (select name from datamaster where social number = 'xxxx') and put this value in input text field because i need make some kind of help in my demo, thats possible?
Hi Ivan,
Perhaps this tutorial (http://www.justinmind.com/support/cre...) would help you create this.
c421da14ca4bd717caef50b09d1716c0
Hi Danielle thks by tou answer, i send you a picture trying to draw my problem, when i click one red point in the map, i show a kind of help with 4 fields, these fields must be select from my data master but i dont know how to select these 4 fields because my data master have 10 fields, i make the filter but i dont know how to put these values in that imput field text, in input field text properties put in each field the data field of data master but dont Works, i expect understand me. :)
Hi Ivan,
Check out these tutorials, which show you how to make your data master search filter fill an input field (http://www.justinmind.com/support/how...)
Hi Danielle, thank you, my prototipe Works correctly, thanks by your quickly answer.
