Upvote 4
Fonts in Prototype too big - Different from Simulate
Known Tessa Hanafin 7 years ago
Hi there.
When I simulate my screen everything is perfect. However, when I saved it as a prototype, some of the text runs over to the next line and looks terrible. I sent the prototype to my client and then had to delete it before they saw it as I would have been so embarrassed. Really, this is driving me nuts!
Has anyone else had this happening... See attached files...
OK, I have figured a workaround. I went into the text boxes, put two spaces after the word (which made the text box increase in depth not width. I then manually pulled the text box wider. Was not able to increase the text box unless I did this. While this is fine for a temporary fix, this would be maddening to have to do all the time, as it does not show on the simulation, only in the published prototype. Very, very annoying.
We've replied to your inquiry in the customer support portal.
Thanks Danielle.
